wemay
Site Donor 2023
We've all seen the posts where a member offers genuine advise to the tune of, "i would recommend a heavier viscosity so you have more of a cushion...." As opposed to running what the manufacturer recommends.
How much is a cushion worth? Does it really afford you the ability to transform a vehicle with a machining issue, dilution, design flaws, into a reliable non-oil consuming ride for an appreciably longer period?
Assuming it's under warranty, would you even want to mask what you consider an issue since it may only "prolong the inevitable" (if a design flaw) until after your warranty is over, if that long?
EDIT: not talking about cars you take to the track. Just daily drivers.
