So right now, I'm just running some cheap walmart oil for 2-3k to help clean out the crank case. Just wondering what oil would be best to run in this car. Right now I've got 5w30 SuperTech from Walmart in the crank case. and upon further inspection online, it appears as though Ford back speced the motor to run 5w20. I was thinking about running some GC in it, but I haven't a clue as to where to find it. But I am open to suggestions as to what to run in it.
Car back ground: 2000 Interceptor, Retired from service probably in late 07 or 08 with roughly 104k on the clock. Sat at motor pool until auction. Sticker on the window said OC was due at Jiffy Lube way back in 07. The oil that was in the crank case looked okay, (still golden in color, no grit etc) but I changed it anyways after giving the car a good 60 mile jaunt around the Tulsa area. Oil came out black as a tire. (Yes, I know. Color isn't everything)
