Hi all,
I recently bought a used Craftsman front tine tiller (917.292381) and the belt drive seems to want to not let go after you engage it. When I first got it it was making a ton of metallic racket and I found that the bottom belt guide for the engine pulley was bent in that it was touching the idler, the one that engaged and is supposed to disengaged the tines. I bent it slightly to get it out of the way while also not being too close to the engine pulley.
Could it be that the belt is too short? The idler/engagement pulley has zero tension on the belt and it's still running the tines.
