JHZR2
Staff member
I was replacing delivery valve seals on my 1991 300D injection pump.
When I was done I was looking the engine over, and looked around the turbocharger. I saw a black bar laying under the turbo on the engine mount.
I pulled it out:
A little sleuthing and I found it. EPC calls it a “Turbo Stay”.
I pulled the other end. It’s like a bent pipe with a welded flat plate on one side and a welded ring on the other. It cracked at the bend.
The round thing welded at the bottom allows the brace to essentially sit over a nipple on the engine block that has the female threads for the bolt. This tells me the brace is in compression, supporting the weight of the turbocharger and manifold.
The break/crack is right where the pipe was compressed and bent. A weak spot. Is that weldable to repair it? If so, what kind do I need to go find?
I’m not able to find the replacement part. I suspect they stay with the turbo or engine. Most used turbos I see don’t have it.
What would be a good way to fabricate it? I don’t weld. I think maybe I could make something sufficiently equivalent out of 1/4” thick angle iron and it would be good enough? If I heated it up I could bend it. I was also thinking maybe a box end wrench that fit over the nipple on the block, bent and drilled on the other end.
Any suggestions?
Thanks!
I pulled it out:
Any suggestions?
Thanks!
