What's the correct way to install a fuse tap?
If you plug it in one way, the two circuits (existing and auxiliary) are in parallel at the source, both draw from the same source and are fused independently.
If you rotate it 180 degrees, the auxiliary circuit (and fuse) is wired in series with the existing fuse. So the current from the auxiliary circuit first has to travel through the main (existing) fuse, then branching off to its own fuse. In this configuration the auxiliary fuse would have to have the same or smaller rating as the main fuse or the main fuse blows. (the load of both circuits can not exceed the main fuse).
My thinking is that the latter configuration is the correct way, as it protects the original circuit from being overloaded. For example, if you have a 20 amp circuit for say a cigarette lighter, then you use a fuse tap to add some LED spotlights using a 10 amp fuse. If you orient the fuse tap using the first method, you could then draw 30 amps from that circuit (presumably designed for 20 amps) with no fail-safe. Using the second method you are still limited to a 20 amp current draw which protects the wiring, relays, etc that are part of that circuit.
I've seen some listings on Amazon stating to install these using the first method, and there's endless threads on various forums saying the same. I think this is wrong. Am I the only one?
