coolant test strips
Minneapolis
They are ok in a pinch. But they are not the most accurate. When in doubt use a bulb type or a refractometer. They will generally be ok, if you are testing coolant made by the same company making the test strip, but I have seen very odd numbers when trying a test strip on a different brand of coolant. Maybe the add pack has a different ph or something.
Michigan
if you're trying to measure dca levels in a diesel coolant, they work well for that. so long as they are not expired or have been exposed to air too much.
SE
It can be challenge at some parts stores . Be sure to check the date at the counter.
Bad Axe, MI
I use CTS for DCA but NOT for antifreeze,use a regular tester bought at any auto parts store for that. i found when doing my DCA tests and then compare the freeze results from the test strips the test strips were waay off like 5 deg or more! don't trust them.
