Hi,
Quick question! Everytime I check the coolant level in my radiator (not the overfill reservoir) when the engine is cold, there is barely enough coolant covering the core. If I fill it up again, heat cycle the engine, it dissappears again, presumably into the overflow tank.
My understanding is that as the motor cools down, its supposed to pull coolant from the reservoir tank back into the radiator itself and my car isn't doing that. Is it a problem? I've replaced the radiator cap, and it does not seem to solve anything... Btw the car does not use any coolant 'per se'.
Thanks!
Thanks!
