Slow drip from where the pipe joins the elbow on the block. I think the pipe would be difficult to remove. Don't know how the joint is formed. Might be threaded or brazed. Not much loss of coolant yet but its a fair bet that it won't get any better.
I suspect y'all will consider it your patriotic duty to recommend JB Weld, so I'll say it up-front :
You cant get JB WELD here
though you can get various 2-part goops with Chinese writing on them that are probably quick setting epoxies.
In the UK I'd probably try my twin-carbon arc brazing torch on it, though I never actually used it for that and I doubt you can get those here, or indeed anywhere these days.
So I'd ideally need a solder or braze that'll work with a fairly low temperature gas torch and minimal operator skill. Maybe silver solder, which I might be able to score from a jewellry workshop.
The coolant is fairly fresh, but I dunno what's in it. Its green (container on the lower shelf on the left)
Heres what else is readily available. One of them looks like PEAK (what a coincidence) but isn't, though I have seen apparently genuine PEAK stuff here in the past.
