OK guys this problem has been going on long enough and I need some help if I am ever going to solve it, so here it goes.
Ever since I have had my 1988 Camaro IROC 350, I have had a coolant issue. At first, after driving the car and turning it off, I would hear and see the coolant boiling back into the radiator. Every weekend, I would have to refill the reservoir, because it would be empty. I thought this was strange, because my gauge always said I was running at 220 or below, except for a few select times when it spiked while driving in heavy traffic on a really hot day. It would drop back down to operating range pretty quickly though. Someone told me to try and replace my radiator cap, so I did replace it with a GM 15 lb OEM cap. After I replaced the cap, the boiling of the coolant stopped, but I would still have to refill the reservoir once a week, so it didn't solve the mysterious coolant loss.
The next issue involved my heater control valve. A piece of this part broke off in one of its connecting rubber hoses, and antifreeze was shooting everywhere. I thought maybe a loose connection here could be the answer to my coolant loss, so I replaced the HCV with a OEM part. It didn't help the issue, I still had to replace the coolant at the end of every week.
Now that you know the issues here are the known facts. I think my secondary fan or one of its switches/relays could be faulty. My primary fan always kicks on at 220, but the few times my car has gone to 240 or above, the secondary fan wouldn't turn on. I tried to test the secondary fan by putting my A/C on max and also by tapping into the ALDL, which should activate it. Neither of these things started the secondary fan. I'm not sure if the fan itself is junk or one of its relays, but I have trouble believing this is causing the loss of fluid because my gauge barely ever goes above normal operating range.
There is never any visual signs of coolant loss, on the ground or under the car, no visible leaks near any hoses or the radiator itself. My oil and tranny fluid are not contaminated with coolant. My car never blows white exhaust and doesn't smell fishy, (well it started to a little after the HCV blew coolant all over my engine, but that is self-explanatory). But every weekend, the fluid reservoir is empty. Even though the coolant doesn't viciously boil back in the reservoir anymore, after it has been filled and driven it does steam a bit out the vented reservoir cap, like it may be a bit too hot. I always fill the reservoir with an even 50/50 mix of Prestone green and H2O.
What I am hoping you guys can help me do is come up with a plan of attack that will help me cancel out things so I can figure out what the issue is. I don't want to bring it to a general mechanic and ask him to check out the cooling system, because I know they will just start replacing everything and it will get costly. Would anyone be willing to conjure up a list starting with the easy small stuff and working up to the bigger things, so that I can begin to figure out what is wrong here? Any input or ideas would be totally appreciated. Sorry for the long post, I just want anyone interested in helping to understand all aspects of what I am dealing with here. Thanks in advance for your advice!!
JCRULZ
JCRULZ
