Originally Posted By: sayjac
Not to be diagreeable, but rather as a point of information. Some time ago, IIRC tenderlion (a Bitog member) emailed Peak Old World to ask about Peak LL and Peak GL. The reply stated that Peak LL contained 2eha, and as advertised on it's website Peak GL did not.
Also, if you read the msds it says, proprietary Hydrated inorganic acid, organic acid salts: < 5% I suspect it could be in that propiety ingredientes which includes both inorganic acid and organic acid salts. And, all contents may not be listed on msds sheets. It is my impression that they are designed first as safety information, rather than a comprehensive list of content.
I don't think you are being disagreeable here, and I agree with you here. See we don't disagree on everything or that much. I'm convinced Peak Long Life and Peak Extended Life are the same product and both are 2-EHA formulas. If you look on the back of the bottle of EL and LL they both have the same proprietary inhibitor, NJTR.. or something to that effect. So they are the same, and a MSDS doesn't tell you specifically what the inhibitor is.
This isn't really important to whether they are the same but as far as I know, it's only called Extended Life at Walmart stores and most other places it is labeled Long Life. It's not unusual for a manufacture to make some little packaging change for a major retailer to to easily distinquish their stock from other retailers.
Quote:
That said, I've used universal coolants, first Prestone, now Peak LL for ~ 5yrs in two different Asian makes, with regular 2-3yrs maintenance flush, with no issues. For me, with or without 2eha is no biggie either way.
Well you are bolder than most people are, but this just provides more support and proof to the contention that assuming no air gets in the cooling system and you have compatible gaskets, dexcool/dexclones do not cause issues. Apparently your pressure cap and reservoir system have been working good. I'm not sure I'd run a Dexclone but I think Prestone might be the better choice between it and Peak. I was at Walmart earlier and they were practically giving away Prestone AM at $8.50 for concentrate plus a B1G1 mail in rebate. that works out to the equivalent of just over $2 for a gallon of premix.
