Are both photos taken from the back of the engine? Agreed it looks like a SOHC valve train, but wondered where the timing chain(s) were, and then realized that they must be on the far side.
The new 7.3 is a OHV/pushrod engine.
Agreed, but these photos are of the 6.2, aren't they?
You're right that is, I think. The 6.2 uses a dual plug configuration with one plug under the coil like on a 2V 4.6/5.4 with a wire going down to the second plug where it would be on a pushrod engine.
Regardless, OHV or OHC, there had to be timing chain somewhere (either a short one up to a cam-in-block camshaft, or a long one way up to the heads). It took me longer than it should have to realize the photos were of the back of the engine.
