That's sad. If you want people to do something, make it as cheap and easy as possible. So how many people just take the easy way and dump it down the drain? How many quarts does a Hummer hold? Maybe Arnold will straighten this out.
I find running to Jiffy Lube a nuisance, but they never question me dumping 3 gallons at a time. My biggest problem is that every time I go to change oil, I find all 3 jugs still full from the last change. Then I leave the drain pan setting around until I hit the Jiffy Lube. The dogs have to go through the garage to get outside. So far, none of them have stepped in the pan of oil.
