OVERKILL
$100 Site Donor 2021
Per my other thread, we opted for the Continental TerrainContact H/T tires over the Defender LTX due to a rather massive price difference. I had originally ordered the LTX, but my dealer had no problem changing the order.
We now have ~500km on these, so I thought it time for some initial impressions.
1. Firmness/sidewall stiffness
These are XL rated tires and I must assume that has some impact on sidewall stiffness. They have very little roll-over in corners; significantly less than the Goodyear ones they replaced. I do not consider this a negative attribute, it firmed up the ride ever so slightly but improved "connectedness" and made them significantly more responsive as they lack that delay in response in input from the wheel that we'd experience from the Goodyear as it would roll-over.
2. Wet traction
I can't even begin to describe the difference in behaviour on wet pavement. These are extremely grippy, which was one of my main buying criteria, so this has me extremely satisfied.
3. Quietness
They are as quiet as you'd expect a tire with a highway tread to be.
4. Dry traction
Extremely good, they bite very well when you roll into the throttle. The Goodyears were not bad in this department, but these are a fair bit better.
5. Handling
This ties into #1, the tires are much more responsive and seem to grip well in corners. The lack of roll-over inspires more confidence and so this is overall a pleasant experience and unexpected improvement. Of course this is a truck, so one has to keep that in mind.
Overall, I'm pleased with the purchase at this stage, we'll see how this holds up as the miles accrue.
Some filthy pictures. As I've noted before, I do NOT use tire dressing, on any tires I own, so these will never be shiny. Of course the truck is filthy too
2. Wet traction
3. Quietness
4. Dry traction
5. Handling
