But think about it this way, how much of that 600ppm of moly actually plates up on the metal? Nowhere near all of it. So what happens with the rest of the moly? What effect does it have?quote:
Originally posted by satterfi:
If cost is not a factor, use Redline.
I doubt Redline uses too much moly. They've been making oil for umteen years. Do you think they would add more moly if they thought it wasn't necessary or even detrimental?
That's one way to look at it, but remember, Redline does not advertise anywhere that they use moly. Only those of us "in the know" are aware of this info.quote:
Patman
I guess for $8/qt some people expect over kill.
If it only had 200ppm moly they might have to sell it for $6/qt
I'm not saying Redline isn't good, believe me, I think it's top notch, I'm just very curious as to why it has so much moly. Shaeffer's has proven that with 150ppm of moly it can do a great job of low engine wear.Patman,
You also have to take into account the type of moly being used by Redline and Schaeffer, which is top secret information I'm sure. With Redline's Moly of 600ppm, maybe 300ppm may only plate up, BUT if it had only 300ppm to start, would the whole 300ppm plate? I don't think it will.
Regards,
Oz
P.S. Yes, unfortunately, Redline is quite rare up here in Canada and quite expensive.
Yes Spector, I believe you are correct. AMSOIL's Full-Synth. lineup (ASL I believe) has more than 10% Zinc/Phosphor content which API SL does not allow.quote:
Originally posted by Spector:
API Doughnut
Well, I am not sure about RedLine but I believe that Amsoil cannot become API certified due to the high amounts of phosphorus and zinc. So even if they tried they would not pass? Someone can confirm that. Not sure if RedLine is in the same boat.
