I have a Pontiac Trans Sport with the 3.4L v6. I have heard that this engine "likes" 40 weight oils. However, I've always used 30 weight oils. I used a good 10W30 dino up until around 50K miles and have used AMSOIL (both 10W30 and now 5W30) since then. I now have over 80K miles on the vehicle. There is no noticeable consumption between oil changes and I usually drain at around 6000-7000 miles, which comes to about 6 months for me.
My question is this: if my engine does not use oil, and seems to be running fine, is there any compelling reason to switch to a 5W40 oil like the new Mobil SUV or the new AMSOIL 5W40?
I know I could take a baseline UOA and then switch to 5W40 and compare, but I'm concerned about going back and forth between a 30 and 40 weight oil. If you go to a heavier oil is there any chance that going back to a lighter oil would damage the engine or caused increased oil consumption?
David
