Comparing Strength Of Modern Building Materials To Older
Thing is that the bricks back then were pretty much the only thing a buildings walls were comprised of whereas modern bricks are more decorative as there must be a structure like wood beams to support it if it's to meet X regulation.
In Mexico they still make the walls and roods purely out of cinderblocks cemented together. No frame or anything and it works well enough.
Only in the US/Canada really. In Europe preformed concrete blocks are the dominant construction material. Much more durable, longer-lasting, better insulating, more fire resistant, better soundproofing... Stick-frame construction is only used because wood is cheap. My European friends think it's really dumb we still build houses out of wood in 2022.
I work for an civil engineering company - these days it’s not so much material but how it’s engineered to meet seismic and structural codes for where the building is going up.
Yes, there have been a few blunders like Millennium Tower. Engineering firms will spend thousands of dollars on specialized CAD/CAE programs to do everything from foundation design, structural analysis(the programs SAP2000/CSIBridge are good examples of this), and even the design and analysis of pre-stressed concrete. AutoCAD and Microstation are used primarily for the drafting phase. Engineers can find out quickly if a building will hold up in an earthquake - you engineer a building to strategically fail(shock absorbers, structural fuses) but fortify critical elements to protect lives.
Residential construction of single-family and condos hasn’t caught up with the advances made in commercial construction nor are the builders of such are going to invest in advanced CAD/CAE software/training unless it’s mandated by code.
Imagine being 1000 or 1500 feet up and in a magnitude 9 earthquake? I’ll take modern materials over old.
Yeah it's cheaper that way and it's just fine honestly. People say it's bad quality like a plastic intake manifold but I've got over 320k on one and it's just fine. The old house I rent out built in the early 80's is brick and wood and it's all original aside from a small renovation to charge more for rent. But I was expecting some damage to the wood but no it was just fine. The brick was also fine just a pressure washing.
