I think Fuel Power Works pretty good as a combustion chamber cleaner. I also think Amsoil Power foam works well.
I'm not telling you to do this, but I use FP a bit stronger than they (LC/Otis) recommend if the car has heavy deposits. A few ozs of anything in 20 gallons of gas is not going to blast 250,000 miles of cc deposits.
Also, it takes longer to clean than the miracle claims. A high mileage car with lots of deposits didn't get that way in 15 minutes and it's probably going to take longer than 15 minutes to clean!
I also second careful use of direct ingestion....I have seen water, various OTC solvent solutions, Amsoil Power foam directly sucked in, mosquito fog out and clean cc's (visible with borescope) result!!!
