Originally Posted By: Vern_in_IL
Originally Posted By: Nyogtha
Not completely accurate - see the network of blue colored lines on this map, including the Midwest, showing US refined products pipelines.
http://www.api.org/oil-and-natural-gas/w...l-and-pipelines
See how many flow northward from the USGC?
The blue colored lines are natural gas. It has always flowed from the gulf, at less than 60% capacity, Trunkline even abandoned a 30" line to convert to a petroleum line.(complements the Keystone pipeline, or to get around the politics, it is under the radar) The big cluster east of St. Louis is the Patoka Tank Farm, the southern "red" line is the old "Capline System" it does flow north, however, they want to reverse flow(Canadian Oil) but a small shareholder(BP) refinery cannot use the Canadian type crude. It is running at 30% of capacity.
Canadian crude wants to flow south, and monsters like Energy Transfer and the Dakota Access Pipeline is putting pressure to reverse flows.
You must be looking at a map different than the one I linked as the legend in the lower right hand corner of the map at the link I posted clearly shows the blue lines as refined product pipelines.
Try looking again.
