Coil Date Code Help
USA
Need help identifying the date code on this coil:
If I'm guessing right, it looks like December of 2014 is when this coil was made. Can anyone confirm?
From what I understand about Ford/Motorcraft parts are the date code is usually on the packaging and lot info is on the part itself. Not real sure to be honest. But if not, I actually look at that as the 14th week of 2012. That's how the FBody codes worked anyway.
The truck is a 2015, made towards the end of 2014. So that is why I was thinking that might be December 2014. It looks original though, and the truck has misfires on multiple cylinders so I thought I would start with the easy stuff first.
This is a Ford F-250 with the 6.2L gasoline engine. Known for coil issues, broken valve springs. I hope to clear up the misfires with this fix.
I can’t find a supersession chart either for this coil so I can figure out when it was installed
