Hi,
my car (Volvo S40) is equipped with an hydraulic clutch command. Today I wanted to check the pedal travel to compare with specs and found a surprising thing: the first 1cm of clutch pedal travel moves the master cylinder piston but this movement is not transferred to the slave cylinder. If I depress the clutch pedal by hand, I can feel there is almost no resistance for the first 1cm although the piston is pushed in the master cylinder. After that I can feel a constant pressure throughout the rest of the clutch travel.
At first I thought it could be air in the system but I pressure bled several times and my Volvo dealer did it also but the same "slack" remains in the pedal. I have no particular problem with my gearbox but I'd like to know if this behaviour is normal or if I should pay attention and fix it.
Most people will tell me that hydraulic clutch have no pedal adjustment but my car has and Volvo gives some specs for pedal height, travel and free play. They mention that free play must be adjusted without pushing the rod into the master cylinder so what I observe is not free play, it's movement of the master cylinder that is not transferred to the slave. Is there anything specific to know to bleed a master or a slave cylinder that cannot be achieve by a standard pressure bleeding??? Is it possible this 1cm slack is due to something else than air in the system??? At last, is this normal or should every bit of master cylinder movement be transferred to the slave cylinder???
Thanks
