Clorox bleach shelf life... I had no idea.
Gainesville FL
Today I decide to clean the patio furniture, deck, and soffit/gutters with the gallon of Clorox Outdoor bleach I had laying around. I have had the gallon for about 6 years.
I mixed in 20 ounces of bleach to one gallon of water in my sprayer and went to work. I got less than stellar results and it took a few applications along with scrubbing to get rid of the mildew.
Afterward I discovered that bleach has a 'shelf life' of about a year. Hmmm who knew.
stored in the dark, sealed, new it lasts better
than half full sitting on a shelf in sunlight
but 6 years is a long time.
Dishwasher detergent, laundry soap etc all have shelf lives too..
A typical commercial bleach solution of 8.25% sodium hypochlorite, if stored at 68f, in the dark and in a perfectly sealed container, ie under perfect conditions, will degrade to a 6.5% solution in 180 days. Increase the temperature or add a little bit of light, then it degrades much faster.
Since most household bleach is sold at 5.25% strength, it's easy to see why bleach has such a short shelf life.
I worked as the laundry product line manager for North America's largest Institutional chemical company. Sodium hypochlorite, i.e., chlorine bleach, has a much shorter, practical shelf life than most people imagine.
In a very competitive environment, we advertised our "bleach" at 7% chlorine. We actually manufactured it at 10%. The 10% formulation ensured it could be shipped to a distribution point, then to the end users and allow it to actually deliver the advertised strength by the time it was typically consumed. Under "normal" or "correct" storage conditions that would typically be about 90 days from manufacture before it fell below spec...and that was with a pH stabilizer that helped to prolong shelf life.
As correctly mentioned previously, storage conditions have a huge effect on shelf life. Exposure to direct sunlight will knock the chorine out of solution VERY quickly (hours). Opaque containers help greatly. Hot storage conditions and containers not tightly sealed follow in descending loss severity.
Most of the brand name chlorine bleach sold for decades in consumer outlets (grocery stores, big box retailers, etc.) was around 5% if really fresh, and the "off brands" may only be around 4%. You can see, with the weaker starting concentrations, the half-life deterioration is going to mitigate its performance pretty quickly. Lately I see some consumer "extra strength" bleach offerings, but if you do the math (ppm to ppm working concentration), they aren't a better value (they're higher profit, surprise, surprise).
Moral of story...use it or lose it. 30 - 60 days gives you the best performance bang for your buck on consumer grade stuff.
(Edit: By the time I typed and posted this, I see Ripcord in post #5 said basically the same thing, albeit notably better to the point!)
At the hospital my wife worked at before, she was given 8 x 1-gallon bottles of bleach because it was "expired". We refill our spray "Clorox" bottles and she uses it with laundry. It works fine for our usage and it definitely still smells strong.
I saw gallon bottles of bleach on sale at Menards a while ago. The Clorox bottles were 2x the cost of the store-brand bottles. Why ? Clorox had 2x the chlorine level !
I learned something today, only buy the smallest bottle of bleach. It is foolish economy to get the big one only to have it expire before used up.
I found a web page that tells how to decode the bottling date of Clorox bleach from the code printed on the bottle. For example, XX25123XXXXX would have been bottled in the year 25 on the 123rd day of the year.
How worried is Clorox about expiration if consumers have to decipher random numbers on their bottles ? If they were, they would put "Best by XX/XX/XX".
Pool shock at 12% is best value
You have to be careful not to swap that for laundry-grade bleach though 'cause apparently it's too strong and can damage fabrics. Who's going to remember to use 1/2 the amount ?
I can see why they would think that it would not be in their best interest for the customer to know exactly how fresh their rapidly degrading product is.
I had (name brand) laundry detergent go bad.
The bottle was about 18 months old and started to collapse.
The color changed and it had an odd smell.
Customer Service told me the enzymes went bad.
