Hello!
I have a problem with my 2013 Lexus GS 450h. It has a really loud clatter after the start up. First thing what might get in mind is the VVT-i system but this problem is a little bit bigger.
The garage changed the timing chain, because it was slightly stretched (including the three tensioners and guides). As the problem still persists they also changed the intake VVT-i and the oil control valves. But the problem is still here.
The thing is: when the car is started cold it makes this noise (when the car was warm before), when the car is started hot it sometimes makes the noise (depends on the time it was sitting). I assume it must have something to do with the oil viscosity, because when I start the car and shut it off (without letting it warm up) it does not make the noise with the next start-up (as the oil won’t bleed out when it is still thick). I am running out of ideas so I seek help with experienced people. Is this a know issue? Maybe somebody already had it?
