I've been a 5W30 guy myself(QSUD 5W30 is a go to oil for me). Especially because I don't see the difference in fuel economy and I find the 30s to keep my engines that little bit smoother & quieter.
In my opinion 0w20 is superior to 5w20. I have experimented with both in my Subaru and Hyundai GDI and both engines run noticably better when using 0w20.
0W-20 generally might be more likely to use a better quality GTL or PAO. However that may just be to cover the deficiencies of using a lower viscosity base stock.
Unfortunately a 1.5 mpg increase is not due to the change in oil grade. That defies physics.I recently changed from 5w-30 to 0w-20 in my Ranger and it has never run so smooth and mpg is up too. About 1.5 mpg. And that's on SuperTech!
I think i know what you're referring to, can you show the graph of temperatures where it shows 20 isn't enough down there in SC?Ill always use a 30 over a 20, my climate doesnt call for a 20 and I could care less about a .20 increase is gas mileage. )
Could you elaborate on the deficiencies of 0w20 as compared to 5w20? Personally I have seen countless examples of synthetic 5w20 oils that were lower in viscosity, on paper, versus the same brand and product line 0w20.
Actually, physics support my statement.Unfortunately a 1.5 mpg increase is not due to the change in oil grade. That defies physics.
Yes, and is always the case, measuring something is only the beginning. Being able to attribute the measurement to an isolated variable is the much more difficult part.Unfortunately Your increased gain is more than a magnitude greater than what can actually happen given your post. I am sorry to disagree with your statement, and I do not doubt you may have experienced a MPG increase you posted.
You may need to remain open to another explanation. There is an overwhelming probability that the viscosity change is not the cause of the majority of the improvement you are experiencing.
INCORRECT!No problemo.
You may not be accounting for interrelated controls and mechanisms of a modern engine that can snowball in to a worse than anticipated result.Unfortunately a 1.5 mpg increase is not due to the change in oil grade. That defies physics.
a 2005 Ranger 3.0? It’s a pretty straight forward reliable design.You may not be accounting for interrelated controls and mechanisms of a modern engine that can snowball in to a worse than anticipated result.
My Jetta shouldn't have lost 6 MPG aver going from a 20 to a light 40 grade. But it did. And it did result in a detune of the engine.
Going from a 20 to 40 is pretty significant in an engine that calls for a 20. So would leave that out of the equation of a 20 to 30.
On the Dodge V8 engines, going to a more heavy weight oil then recommended can interrupt the operation of the cylinder deactivation at highway speeds due to increased drag. I cant get into specifics though, just sold the truck, had a 2008, best darn engine I ever had but was the 4.7 v8 not the mag V8 which in my owners manual made a ref to what I am trying here.
So I am wondering on the VW if some situation might be similar.
I can agree with some though, that say they notice an MPG difference from 20 to 30. But who knows, maybe with some super small engines? Like a Chevy spark?
