Citgo 10w-30 For Exmark 708 cc V Twin?
MD
I have a few cases of this oil and I use it in my MF Diesel tractor.
I have a new Exmark Zero Turn on order ( 708 B&S V-Twin) and want to use the same oil.
Would you use it?
It does not say here but other Citgo literature said it was idea for fleet use including "gas" engines.
First oil change is 10 hours!
Thanks!
http://www.docs.citgo.com/msds_pi/C10166.pdf
Should work just fine.
I'm using Castrol Gold 10W-30 in my Exmark/Kohler right now. But I got the stuff on sale cheap last year.
Any name brand 10W-30 will do.
That is a heavy duty synthetic blend engine oil designed for diesel engines.
In other words, IT IS IDEAL for your power equipment. It's an excellent choice, and since you have a couple of cases of it, it's a solid no brainer. Use it with confidence.
That oil is probably very similar to the Shell Rotella T5 syn blend 10W30, which is also an exceptional oil for power equipment.
Thanks Bubba
I'll be in your state soon
Moving to just outside of Palm Coast
