- Messages
- 769
- Location
- Palouse WA
My ex brought her 92 Voyager with a 87 2.5 L engine in it for me to try and fix and sell. The problem is 1: oil light flicker on and off at idle especiall if there is a load on the engine such as turning the steering. 2: There is a horrible sound coming from the engine that is more a rattle then a nock and it is coming from the timing belt side. I am thinking valves (oil starved) or the water pump or the timing belt idler bearing (that is brand new) It sounds more like a spinning bearing gone way bad then an actual internal engine bearing.
Any Ideas?
Ken
