- Joined
- Nov 29, 2009
- Messages
- 9,513
This engine is funny. Usually it's really easy to pull the pull cord and you have to be careful you don't pull the cord out too fast, because you'll hurt your shoulder. Then other times, it's harder to pull and it doesn't necessarily want to start. it's always started fine down to about 50 degrees, except today it was 38 and I couldn't pull it hard enough to get it to spin fast enough to turn over. Gave up, then tried again on the next yard and it started right up and was easy to pull. I tried adjusting the choke a while back, but didn't really see how it could be adjusted anymore. (I think that was it) I can't remember. I know it's got some type of easy pull start system, not sure if it's a spring loaded recoil or maybe it's a compression release on the camshaft that makes it easier. It's only got about 35hrs on it now, so I don't see how the valves could be out of adjustment. This is the first time I actually wasn't able to start it. Usually if it's hard to pull the recoil it just takes a couple more yanks on the rope and it starts. I also, don't like how these engines don't have a primer bulb. I bet it just needed to be primed, then couple that with cold weather and it was probably just flooded.
