Chevron Supreme or Mobil Clean 5000
Originally Posted By: Oregoonian
I would reccomend MaXLife Blend 5w30. Its made by Valvoline and its a great high mileage oil that can help stop leaks
Its sold at Walmart in 5 gallon jugs and at a price that is not much more than a conventional oil (like Chevron Supreme or Mobil 5000)
And while at it, get a good upper tier oil filter (stay away ftom Fram). A Purolator PureOne or Bosch Preminum at less than $6 are the best.
________________________________________________
2003 Ford Focus SE 2.3L / 82K
Valvoline MaxLife 5w30 Syn / OCI 7000+/-
Purolator PureOne
Redline SL-1 Complete Fuel System Cleaner
MC5k is the best dino! He stated that he was going to do his oci's at 5k so there is NO NEED for those premium filters. A Purolator Classic/Premium or NapaProselect will work fine for 5k oci's!!
I'm pretty sure he did. I had put it on before and it was still leaking after I put it on. And I would think that it wouldn't leak only on one side if it was the valve cover gasket. All of the bolts are torqued the same
1/2 quart in 5k is nothing for leakage.
I'd give Maxlife 10w30 a try. Coming into summer, the 10w30 will be a good viscosity.
Ok, so my manual calls for 5w30, why would upping the viscosity during summer help?
Would it provide extra protection since you don't need to worry about starting in the cold and wouldn't need a thinner weight?
Exactly. If you don't 'need' the '5W' ability of the oil, a '10W' oil is a bith thicker, and a bit more shear-stable, so it will thin less. Not a lot, but some.....
Purolator PureOne
Even a supertech
