Some history, I replaced head gaskets on this car immediately prior to the 2 most recent UOAs. I had a fair bit of coolant in the oil prior to the repair (I purchased the car like this), so I began the UOAs after the HG replacement with the expectation that any residual coolant would trend downward.
Blackstone noted coolant contamination on the last UOA and suggested sampling again at 3k, so that's what I did. Strangely, signs of coolant have increased slightly. I haven't had to add any coolant since the repair, it stays rock solid at the same level in the reservoir, so I'm a bit perplexed why potassium and sodium have increased. The high silicon is a mystery to me, new air filter was installed at the same time as HG repair and intake is in good condition. Could this be due to the small amount of sealers used during reassembly?
I'll probably go another 3k and retest as per their suggestion. Sort of a wait and see approach, but I'll be checking the intake plumbing again in the meantime. Open to suggestions/comments/ideas/etc. I replaced the Delo 5w-40 with Harvest King 5w-30 Synthetic (SN+) oil.
