Sam_Julier
$50 Site Donor 2024
I’m really pleased with this report.
This is the second 5,000 mile run with this oil. Makeup oil was 1/3 quart in a sump that holds 4 quarts. Mann W917 filter. Dimple magnetic drain plug.
I‘ve been running dual spec oils in both 240s for quite a while. As you can see the cam shaft and area under the valve cover is as clean as can be. And the oil consumption is minimal.
I plan to stay with these oils and a 5,000 mile OCI. Any thoughts are appreciated.
