Chemical analysis of tribofilms - a couple of pape
'Stralia
https://www.google.com/url?sa=t&source=web&rct=j&ei=fJrBU5qaNtDroASzx4DgCg&url=http://home.physics.wisc.edu/gilbert/publications/90.PDF&cd=2&ved=0CCIQFjAB&usg=AFQjCNH-xEV-jH5LjNE5-_tr7uyjIAqAuw&sig2=UMH3Z_xWMBv1BcE_V6EvOQ particularly read with https://www.google.com/url?sa=t&source=web&rct=j&ei=r53BU5WgJoW8oQTgqIHABQ&url=http://home.physics.wisc.edu/gilbert/publications/101.PDF&cd=2&ved=0CCAQFjAB&usg=AFQjCNGwona7Onh1BMOhjI3f0J7_Ev_nWQ&sig2=SuneuEqHgSOhJViHeJL0jg Interesting on a number of fronts... * tribofilms are formed by reacted ZDDPs; * replacement tribofilms require a reserve of unreacted ZDDP; * different tribofilms based on temperature/surface conditions; * and what was interesting between the AlSi and steels was that more reactive surface oxides seem to help * AlSi, some of the "wear" appeared to be the silicon particles being forced down into the softer Al matrix * second paper talks about the reduction in ZDDP efficacy in fully formulated oils due to the actions of inhibitors and detergents.
North Carolina
Interesting that on the 2nd page( page 49) It mentions that overbased detergents reduce the antioxidant ability of zddp, and that basic detergents improve the friction capability of the oil. I interpret this to mean the really high tbn oils interfere with the zddp putting down a layer?
Greatest Earth on Show, UT
Originally Posted By: Shannow
Linky 1 particularly read with Linky 2 Interesting on a number of fronts... * tribofilms are formed by reacted ZDDPs; * replacement tribofilms require a reserve of unreacted ZDDP; * different tribofilms based on temperature/surface conditions; * and what was interesting between the AlSi and steels was that more reactive surface oxides seem to help * AlSi, some of the "wear" appeared to be the silicon particles being forced down into the softer Al matrix * second paper talks about the reduction in ZDDP efficacy in fully formulated oils due to the actions of inhibitors and detergents.
Shannow
'Stralia
Originally Posted By: michaelluscher
Please embed your links next time so they don't unnecessarily widen the page. It makes it difficult to read
Sorry for the inconvenience...was posting on a phone in a waiting room (reading paper copies)...was lucky that i got what i did in
BC, Canada
"Reduction of ZDDP efficiency from the action of inhibitors and detergents." In the paper it mentioned the bonding of the tribolayer to the surface through oxidation. It has been said that chemicals compete for surface area. So what exactly is new? The heat generated by the high shear rate in the elastohydrodynamic regime was discovered? That would make sense; Italian tune-up gone wild.
down in the park
There was a paper or article by E-ion posted a while ago where they also claimed the AW ingredients became active before there was metal to metal contact from the extreme pressures in the boundary layer formed by their product.
California
Further suggesting that changing oil more frequently than needed might not be a good thing? Thanks for sharing...Great stuff.
