Had a fun one come in today.....
1998 Dodge Ram 1500, 5.2L/46RE 174,xxx miles
*Complaint.....Engine stalls while turning or going up/down inclines, More often when it's cold or after a cold start.
*As I was pulling the truck down the drive to my shop which is down hill, The engine labored & the RPM's would drop & almost die.
This is an easy one guys & I've seen this issue on several vehicles......
The transmission fluid is very low, If it sucks air, There isn't enough line pressure to keep the Torque Converter Clutch from self applying. This is especially prevalent on old Chrysler products because you must check the trans fluid in Neutral as there is no Converter Feed Pressure in Park.
The customer almost wanted to argue the point as he has a engine problem & the transmission is fine. I asked him about the trans cooler line repair & how he checked the ATF.....We worked it out & now he knows how to check the fluid.
