I have a 2007 Toyota Tacoma with the 4.0 V6 (1gr-fe). It was bought in 2007 with ~3,600 miles, I used PYB 5w-30 for the first 30-35K at 5k intervals. Then I started using Mobil 1 5w-30 and later began using Mobil 1 5w-30 EP. I'll post a pic of the maint records, there are a few gaps in the records, that's where I have had work done at the Toyota dealer and had the oil changed by them with whatever dino bulk oil they had on hands. This isn't a complete list of all work done, I have some things that I have neglected to write down, but I have receipts with dates/mileages written on them in a folder. This vehicle is used daily and often short tripped (less than 1 mile), with lots of idle time. I have a stop or two to make in my daily 1 mile commute and I often leave my truck idling for a few minutes at each stop because it has not yet reached operating temperature, If I don't make any stops and just do my 1 mile commute my truck will be at about 140 degrees F when I shut it down. I do take a longer trip into town once or twice per week which can be a 20-60 mile round trip depending on where I have to go. I have an Ultragauge that I leave plugged in all the time to monitor engine and trans temps, I have alarms set just in case it ever tries to overheat, that way I'll catch it early enough to save the engine/transmission. The truck gets up to operating temperature fairly quickly and holds its operating temperature where it should be, usually 186.6, but with the heater running it'll drop down to 180 degrees F or so. In the summer with the A/C on and sitting still at idle I've seen up to 200 degrees F, but usually it doesn't get above 194. The PCV hoses/valve are original, but I have pulled the PCV valve off and checked/cleaned it several times, it seems to be functioning correctly and is not clogged. I'm gonna buy a replacement PCV valve the next time I'm at the dealer and swap it out.
Pics will be inserted at the bottom of this post.
My current fill is Pennzoil Platinum 5w-30 with a Toyota 90915-YZZD3 filter. I currently have ~148 hours of run-time on this OCI, with just over 1500 miles. According to my UG, I have burned about 143.5 gallons of gas on this OCI, averaging 11.1 MPG at an average speed of 10.7 MPH.
The oil looks great on the dipstick, but my engine continues to get dirtier....???
My previous fill was Mobil 1 EP 5w-30 (Toyota filter), which I ran for 6 months, ~2500 miles and for a total run-time of 185 hours.
The truck currently has 84,234 miles on it.
Although I couldn't get a picture of it through the fill tube (you can see it, I just can't get a pic of it), my truck is starting to get a lot of dark varnish buildup on the timing cover along with some streaky burnt looking places along the timing cover. I've seen this before.....
https://www.tacomaworld.com/threads/sounds-like-a-bad-pulley-wish-it-was.73107/page-3#post-1397889
....... I'm hoping I don't have a failing oil pump like that guy did.
The engine runs great, doesn't burn any oil and sounds normal. It has the typical 1gr-fe tick, but it always has.
I'm almost thinking I should be running a good cleaning dino (PYB, Chevron Supreme, Havoline) and change it every 100 hours, what do you guys think?
