I've been chasing a bad mpg problem with my Jeep for a few weeks now.
Original thread---->
http://www.bobistheoilguy.com/forums/ubb...rue#Post2317313
We found a vacuum leak at the throttle body. I replaced the throttle body with a good used one and my mpg was still in the toilet. I then replaced the 02 sensors with new OEM ones.
Still got 11-13mpg.
About 4 months ago I replaced the spark plugs with new ones. The exact ones that the Jeep calls for and the same number that it came with when I bought it new.
Champion RsomethingEE.
Anyway. Fed up with terrible milage. Changed out the 140 gear oils for 80w90, drained the 15w40 from the engine and put in 10w30 etc.
I pulled the Champions out, checked the gaps(were ok) and they looked good. Still drinking gas!
Bought some Autolite APP985's to try since it liked the last set I used before I put the new Champions in.
Did some off roading today. Slow stuff that wont get very good mpg anyway.
Filled up and checked my mpg. I got 15.8 mpg!
While not great this is where it should be. I actully got better mpg crawling around in the desert with new Autolite plugs than I got with the new Champions on the hwy!
We reciently had a thread where Champions were bashed and I defended them since I had never had a problem with them until now.
The Champoins look fine, no codes etc. How could they effect my MPG that much?
Still got 11-13mpg.
