NEVER. AGAIN.
Book time is supposedly 3.1 hours but it took me almost triple that in the garage with a full set of tools. Since my car has a huge engine shoe-horned in, it is quite involved:
1. Remove intake
2. Remove headlamps
3. Remove bellypan
4. Remove driver's side wheel
5. Remove & drain washer fluid bottle
6. Remove entire front bumper (including headlamp washers, fog lamps)
7. Remove auxiliary radiator shrouds
8. Remove front radiator assembly (3 radiators)
From there you have about 6 inches to reach down/up and remove the tensioner, idler roller, and belt. It took me almost 3 hours just to get everything disassembled. And of course, being a German car, it's all a combination of Torx, hex, and triple-square. With 65k on the clock a few things were rusted or seized. The belt itself was all of 5 minutes to do.
Re-assembling took about an hour, but in all it was a 9+ hour ordeal. I also took the opportunity to swap the front motor mount for a stiffer polyurethane mount (adds about 90 seconds worth of work). Indy shop can do this stuff next time at $95/hr. Parts were only about $150 ($100 for the tensioner, $10 for the belt, $40 for the mount).
The original belt with 65k was a bit stiff and brittle and had some stress cracks, but was probably still good for another few years. The tensioner, on the other hand, was totally seized and wouldn't pivot at all. Engine sounds a tad different now and the stiffer mount removed some of the slop when you shift hard; I can get back on the power much faster now.
My hands and body are still sore....
