Change your manual transmission fluid!
Canada
Just changed the manual transmission fluid on my 13 Golf tdi which has never been changed. I got the car just over 6 months ago and now it has 140000km at the moment, I put in some liqui moly top tec 5100 mtf which is GL4 rated, and I can say the shifts are a bit smoother, but that wasn't necessarily the aim... Well, glad I did, old stuff looked like used engine oil
As far as I know, the manual transmission fluid doesn't have a stated interval and is supposed be "lifetime"... Yea right 🙄
The Tremec 6sp manual in my Chevy calls for 45,000 mile changes of the tranny fluid. Required lube is pretty much Dextron IV. Tremec sell their own fluid now but I’m happy with Redline ATF Equivalent.
"Lifetime fluids" was a marketing ploy, and not a maintenance philosophy.
I'm always amazed by VW service intervals on some of the newer cars. Many complain that service costs are high on German cars, but it seems they are some of the only ones that still use traditional intervals on some items. The GTI calls for 40k mile transmission service on the DSG and spark plugs.
DSG is specific. All Dual Clutch Transmissions have more stringent intervals.
One thing VW did is increase capacity on 3rd Gen EA888 engine to help with 10k OCI. So that EA888 in my Atlas takes 6qt compared to 1st Gen in my Tiguan which takes 5qt.
I like the idea of the 10k mile oil change on the EA888 more than actually doing it. It sounds like a bad idea with direct injection to go that far.
It's almost impossible to find the right fluid for most Japanese cars on the shelf of a US store. Other than Honda, Japanese cars usually take a 75W90 GL4 gear oil, which is all but extinct in the US.
Hondas take motor oil, and most American manual transmissions use ATF. Both can use the Pennzoil and Valvoline Synchromesh you actually find in stores, but it's too thin to use where 75w90 is called for.
The only 75w90 GL4 that's reasonably available is Ultra1plus, which I did a VOA on and didn't turn out too good. The only other choice is an expensive Castrol-made Motorcraft from the Ford dealer, at $30/qt. At that price, it's actually cheaper to order Castrol online from Europe, even with international shipping :sneaky:
Rock Auto no longer carries Valvoline's Professional Series MTF (part # 508216), that was a 75w90. It's primarily sold to shops and may still be available from VIOC, so you might be able to get some if you know people that work at VIOC and/or can bribe them :censored:
The above VPS is NOT the same as Synchromesh!
I’m using this for my 2009 Mazda 5.
