I have a 2002 Ford F 250, 7.3L Powerstroke diesel with the automatic transmission. We bought it at 129,000 mi., and the truck now has 131,000 mi.
According to service records with the truck, the trans. was flushed and refilled at 117,000 mi. with regular Mercon fluid-NOT synthetic.
We tow an 8000 Lb. travel trailer.
I've added a class 4 [12,000 Lb.] plate-fin transmission cooler in addition to the stock cooler, along with an Auto meter transmission temp. gauge.
On a recent trip in the Arizona mountains, with the O/D locked out, I reached temps of 190-200 degrees and once went to 208 degrees temporarily- only for a minute or two.
Temps came down to 170-180 as soon as we reached a level spot or going downhill. The transmission seemed to work fine-smooth, solid shifts and no leaks or overflowing to indicate an overheating problem.
My questions or concerns are:
I'm trying to get the trans. temp down even more to make the trans. live.
1. If I changed to a full synthetic trans. fluid, how much cooler overall can I expect the temps to run?
2. If I go to a synthetic fluid, would I be creating leaks where there were none before? [If it ain't broke-don't fix it?]
3. Suggestions for a synthetic fluid that works best in this Ford auto trans?
Sorry to get so long winded and thanks in advance for any help and suggestions you can give Me.
Bill
Bill
