you shouldnt be able to explode a tire if you dont over pressurize it.
quote:Hitting a tire with anything is asking for a damaged tire. It will eventually catch up with you...
Originally posted by GreeCguy: Still do my own tires. I made a bead breaker a few years ago and that helps a bunch. Till that time, I would hammer them off with a hand sledge and a pry bar. It takes time and you have to be careful cuz you can loose a few teeth if that bar gets away from you. Putting a tire on the rim is a breeze with a hammer and a little liquid dish soap.
quote:so changing a tire with a wood-splitter, pry bars and a can of ether isn't a proper way?
Originally posted by CapriRacer: I would not recommend anyone try to dismount and mount their own tires without the proper equipment and proper training. Aside from the equipment needed to make the job SOOOO much easier, there is some amount of danger involved which can be minimized by following established procedures. There have been cases where a poorly trained person overinflated a tire and it exploded, killing him. I don't want that to happen to anyone at BITOG.
quote:This is kind of what I've been preaching. Nowhere in this document does it mention lubrication of the bead and rim or what to watch out for when mounting a tire. And more importantly, it doesn't mention the 40 psi limit for seating beads. People get killed exceeding these limits. End of sermon!
Originally posted by eljefino: These are the directions from harbor freight for their manual changer. They aren't much but they're what the original poster asked for. http://www.harborfreight.com/cpi/ctaf/manuals.taf?f=form&ItemID=34542 Information is power. He didn't ask people to tell him not to do something. Everyone mounts a tire the first time. ..........
