Originally Posted by Whimsey
I did the a first drain & fill at 12,000 miles,
10,000 miles later I did the second D&F
I did another 10,000 mile D&F
I'll let the current fill go to ~20,000 miles and see how that Mercon LV looks.
Interesting that you decided to wait 20,000 miles for the next drain & fill. Are you sending the transmission fluid in for analysis, or just eyeing it to see how it looks? I'm curious as to what data your experiment will yield.
Why are you draining and filling with just 4 quarts? If you run the vehicle, shift it through the gears, then repeat the drain and fill 2 more times, your transmission will have fresh fluid.
My preference is fluid exchange through the transmission return line. Sometimes the transmission lines are not easy to access, and I will drain & fill. I always do the triple drain & fill, because I've heard it more than once and it's drilled into my thick head.
The fluid and labor for me is cheap compared to a transmission, but that's me.
The math makes sense. Let's say you spend $XXX annually on fluid. Over the course of 10 years, how would that add up against cost of a new transmission? Only variables being that your transmission, after 10 years, even with regular service, may need to be rebuilt anyway because of wear & tear. No transmission will last forever, even if you are changing the fluid. I could wrong. I believe that regular fluid exchange, keeping fresh fluid in the transmission, is better than driving 10 years with contaminated transmission fluid.
Originally Posted by nicholas
Does anybody do a drain and fill on a new auto trans at an earlier interval? Say 15,000 miles? Then go to the usual 30,000?
My strategy for my Ford 6F35 is to do the triple drain & fill every 25,000 miles. I am aware that the factory once suggested that Mercon LV was a lifetime fluid. Then you hear that you should service it at 60.000 miles. Some people recommend 30,000 miles. Dealerships use a machine, hooked up to the cooling and return lines for a complete fluid exchange. Some people drain & fill just once. Some people think that you will be fine, because the 4 liter fill is sufficient to "freshen up" the transmission, since that is almost half the fluid. Some people think that you should follow the manual and do it 3 times.
My strategy for my Ford 4R75E was similar to what you are planning. At 10,000 miles, you've "broken in" the transmission. Good time to flush out the transmission. Get rid of the "break in" metal shear that's floating around in there. Dealership fluid exchange machine flushed out the OEM fill, and refilled with Royal Purple. I drained the fluid @ 20,000 miles, and it was still pretty clean, so I just refilled the pan. At 30,000 miles, the fluid was pretty good, so I refilled it again. At 45,000 miles, I exchanged the fluid completely by pumping it out the return lines. Dark (as expected), no burnt smell, and still in good condition. By now, the transmission had a mixture of Royal Purple, Red Line, Lucas Oil, and some Mercon from Wal*Mart. In hindsight, the boutique oil was a waste of money, and I could have used Wal*Mart Mercon. . Being lazy, forgetful, distracted by prurient pursuits, not driving that car regularly; 1 day I noticed that the oil had not been changed in almost 2 years & that it was @ 80,000 miles. Transmission fluid was dark (as expected), but did not smell burnt. Fluid exchange through the return line, Filled with a Amalie brand Mercon V. Car is now 12 years old. Transmission is fine. Lots of other similar models from that generation have experienced transmission failures.
Only time will tell if your strategy will work for you and your Hyundai. A lot of variables. Your driving style and road conditions will have a lot to do with it. Heavy loads. Hills. Stop & go traffic in 100 degree heat. My only experience with Hyundai is from when they first came on the market, and they were not very well made. I've heard that the cars are better now. What do the Hyundai forum people say?
