Champ PH2835XL sloppy glue application follow-up
Original post here.
In a nutshell, there was just too much potting material on the endcaps and some of it dripped down and formed a blob inside the center tube. Once it was cut open, I gave the blob some heavy poking and prodding, but it didn't budge. The last picture shows the side directly behind the blob on the center tube. I measured the area of filtration material at 73.5 in² with 60 pleats.
That's better than the excess glue that comes off really easily on Motorcrafts. If that one you cut open didn't have the big glue goobers coming out the louvers, it would have been within reason to run. But any crazy excess glue on the clean side is a risk to run.
