O ord_avg_guy Joined Mar 26, 2018 Messages 4 Location Canada Apr 29, 2023 #2 Expensive transmission, I recommend buying a manual and using a oil specified in the manual or call a Agco dealer and ask.
DriveHard Joined Nov 24, 2003 Messages 3,786 Location Middle of Iowa May 1, 2023 #3 CVT with hydraulic pump and motor (similar to Fendt) - follow the manual. If there are wet clutches (brakes), you will need a certain oil, and no matter what it will need to be yellow metal compatible.
