Chain Saw...
MIchigan
Replacing the fuel line on my Chain Saw. Having a problem getting the line down through the body and into the tank. Need tips guys! TIA.
One thing you can do is cut a taper on the end. Push it through, and then you can grab the tip and pull the rest of it through. when you have it through, trim it off.
Yes I tried that but I didn't buy enough extra line to give me an inch taper. Plus I took the fuel filter down and matched up the line with that instead of the original line and it ended being to large. So I'll have to get some more later. Thanks!
http://www.youtube.com/watch?v=JrXpU70Hmi0
