I really like the idea of turbocharged, compression ignition aircraft engines. We could have, and should have, done this decades ago.
I truly know little about aviation, but it seems that whatever entity that oversees design and operation of aircraft (FAA?) is very slow to change.
Still using mags, leaded fuel and carbs- Why? I would assume after reading of the multiple part failures here (mags, starters and sticking valves to name a few) that the electronics and parts today's auto industry runs on would be more than durable enough to provide many hours of safe and reliable operation.
While it's nice to blame the FAA, they really are not the entire problem. Aircraft engines are unique, direct drive, reasonably simple and incredibly efficient. People often think a Chevy Small Block would be a better aircraft engine. Not so. It's far less efficient, it's HP to weight is worse, it's cooling drag (water cooled) is much worse and it's not particularly reliable in "aviation spec".
Even that engine in the 172 (a Thielert variant) was known for early gearbox failures, at 500-600 hours. It eventually became a requirement to pull the engine at 600 hours for "repair", which was simply a replacement gearbox, and often an entirely new engine. The early versions of that engine were absolutely awful, with 300 hour gearbox requirements. And, other parts failed too, not just the gearbox. But fuel pumps, oil pumps etc. Aviation truly is hard on engines.
I certainly hope those issues are worked out.
