Certified labs..Strata Plus
Massachusetts
I was wondering if any one heard of this product or used it....I came across a bottle in work and was curious about it....
this is the info on the site
Contains 13 additives to boost wear protection and double the service life of conventional oils
StrataTM Plus raises an oil’s Total Base Number (TBN) by 5 points to neutralize sulfuric acid, reduce sulfuric acid wear, prevent acid sludging, and extend oil life. Decreases carbon buildup and soot formation so engines run cleaner and compression levels stay high. Improves oil viscosity and raises viscosity index. Cuts varnish, sludge, soot, carbon, and gum with an advanced detergent/dispersant additive package. Inhibits rust and corrosion on rings, cylinder walls, and copper-lead bearings.
APPLICATIONS: Recommended for use in any oil used for internal-combustion diesel or gasoline engines, including engines with turbochargers or superchargers. Works equally well in multi-viscosity and single-grade oils, including synthetics. Can be used to treat new oil and between oil changes.
thanks for any info you have
Al
Well I brought one home to see what it was...I will not put it in my truck since no one knows what it is...so I will try it in my ATV or Tractor....It also says LubeMaster on it...
it is not thick like STP..more like a 10-40 oil viscosity...I wish I knew more about it since I was told a salesman left them last year and no one used it or forgot about it...
Al
Get a VOA on the stuff.
Haven't seen it anywhere? how are they marketing this stuff?
I asked how it got here and was told a salesman came and left it...I guess it is geared for heavy equipment and fleet vehicles..here is the MSDS on it
MATERIAL SAFETY DATA SHEET: STRATA PLUS
Section I - General Information
(000000-000000- - 0540)
Date of Issue:
6/29/2006 12:00:00 AM
Supercedes:
9/14/1999 12:00:00 AM
Chemical Name & Synonyms:
N/A
Trade Name & Synonyms:
STRATA PLUS
Chemical Family:
PETROLEUM DISTILLATE BLEND
Formula is a mixture: [√]
Manufacturer Name:
CERTIFIED LABS, DIV. OF NCH CORP.
Manufacturer Address:
BOX 152170
IRVING, TEXAS 75015
Prepared By:
R Mohochi/Chemist Product Code Number:
0540 Emergency Phone Number:
800-424-9300
Section II - Hazardous Ingredients
THE HAZARDS PRESENTED BELOW ARE THOSE OF THE INDIVIDUAL COMPONENTS
Chemical Name (Ingredients) Hazard TLV PEL STEL CAS #
SOLVENT REFINED HEAVY PARAFFINIC PETROLEUM DISTILLATES IRRITANT 5MG/M3 $1 5MG/M3 $2 10 MG/M3$1 $$
CALCIUM SULFONATE IRRITANT N/E 1 N/E 2 N/E 61789-86-4
MINERAL OIL IRRITANT 5MG/M3 $1 5MG/M3 $2 10 MG/M3$1 8042-47-5
ZINC ALKYLDITHIOPHOSPHATE IRRITANT N/E 1 N/E 2 N/E 68649-42-3
ACRYLIC COPOLYMER IRRITANT N/E 1 N/E 2 N/E 68171-46-0
$ OIL MIST VALUES
$$ 64741-88-4, 64742-65-0
here is a link to the site info....
http://www.certifiedlabs.com/certified/v...article_id=9547
