I have a can of this but have no way to use it for the labeled purpose anymore. (I've moved on to using different products on chains and don't have any cables that need lubing)
www.liquidwrench.com
Would it be safe to use as a general cleaner for firearms and magazines? The SDS says most of the product is petroleum distillates and then a trace amount of the Cerflon lubricant stuff. I figure this would be good at least for a wipe down on guns and mags, although it's not apparent if this has enough to prevent corrosion from humid air.
Chain & Cable Lube – Liquid Wrench
CERFLON® is a ceramic-reinforced fluoropolymer (PTFE). The patented CERFLON® FluoroCeramic technology increases the lubricity and durability for lubricants and coatings! The chemical compound, Boron Nitride, is added to the fluoropolymer PTFE (also known by the DuPont registered trademark Teflon®). Not only is Boron Nitride the only material known to fully reinforce PTFE, in fact, in a 4 Ball Wear Test (an industry standard test that measures the wear protection of a fluid on a metal surface), a base oil compound with CERFLON® scores 15% better than a base oil compound in PTFE alone.
