Wife's car with 19978 miles total, 9988 on the oil, which is VW 505.01 rated. No make-up oil added. Oil changed 1 AUG 06. New oil is the same Castrol TXT 5W-40. Over the life of the car I have added about 1/2 oz. of PS (white) additive per gallon of diesel fuel. MPG runs between 45 and 51 with 47/48 being most typical. Car was driven conservatively except for having been flogged one day at an SCCA driver's clinic by enthusiastic daughter. Analysis by Blackstone.
THE NUMBERS:
Aluminum-----6
Chromium-----2
Iron--------59
Copper-------9
Lead---------5
Tin----------0
Molybdenum---1
Nickel-------1
Manganese----2
Silver-------0
Titanium-----0
Potassium----2
Boron--------0
Silicon------5
Sodium-------2
Calcium---2780
Magnesium---12
Phosphorus-771
Zinc-------939
Barium-------0
SUS [email protected]
Flashpoint---460 F.
Fuel--------- Antifreeze---0.0%
Water--------0.0%
Insolubles---0.4%
BLACKSTONE COMMENTS: Nice general improvement in wear. A lot of these wear levels were a little higher than last sample, though they can still be considered improved since this oil was run a lot longer. The improvement is a good sign that the engine is pretty much past wear-in and free of any mechanical problems. The oil was still in pretty good shape too. The TBN was still strong at 5.9, so there is plenty of active additive left. 1.0 is too low. The cSt viscosity at 100 deg C. was 12.9. No fuel or antifreeze was present. We like the looks of this engine at 19,978 miles.
MY COMMENTS: This is the longest OCI I've ever run on any engine. I'm old-school but am grudgingly coming to recognize that modern oils can provide adequate lubrication over sustained periods in some applications.
THE NUMBERS:
Aluminum-----6
Chromium-----2
Iron--------59
Copper-------9
Lead---------5
Tin----------0
Molybdenum---1
Nickel-------1
Manganese----2
Silver-------0
Titanium-----0
Potassium----2
Boron--------0
Silicon------5
Sodium-------2
Calcium---2780
Magnesium---12
Phosphorus-771
Zinc-------939
Barium-------0
Flashpoint---460 F.
Water--------0.0%
Insolubles---0.4%
