Castrol Synthetic 5w-50 specification/data sheet
US
Does anybody have or direct me to the spec./data sheet for Castrol Syn 5w-50 (pour point, Cst, vi, etc.) I've did a search did not find, searched Castrol USA no data sheets that I could find, Thanks slowlane.
Patman
Staff member
Oakville, Ontario
I scanned in the Castrol data sheet, but it's on my work computer and I'm on holidays this week. Perhaps someone else that I sent that file to could send it to you this week.
vvk
Philadelphia
Here you go:
code:
CASTROL SYNTEC
TYPICAL PROPERTIES
SAE Grade Method 0W-30 5W-30 10W-30 10W-40 5W-50 20W-50
API Service SL/CF SL/CF SL/CF SL/CF SL/CF SL/CF
ILSAC GF-3 GF-3 GF-3
ACEA A1 A1/B1 A1/B1 A3/B3 A3/B3 A3/B3/B4
Specific Gravity, 60ºF ASTM D-1298 0.847 0.854 0.857 0.859 0.852 0.866
Pounds per Gallon 7.05 7.11 7.13 7.15 7.10 7.21
Viscosity, cSt 100ºC ASTM D-445 10.0 9.7 10.0 13.2 17.5 18.5
Viscosity, cSt 40ºC ASTM D-445 54 53 58 89 110 154
Viscosity Index ASTM D-2270 175 171 159 148 175 135
Low Temperature (ºC)
Cranking Viscosity, cP max ASTM D-5293 <6200(-35) <6600(-30) <7000(-25) <7000(-25) <6600(-30) <9500(-15)
Pumping Viscosity, cP max ASTM D-4684 60,000 (-40) 60,000(-35) 60,000(-30) 60,000(-30) 60,000(-35) 60,000(-20)
High Temp High Shear Rate
Viscosity, cP @150 ºC
CEC L-36-A-87 2.95 2.92 3.1 3.8 4.5 4.5
Flash Point, COC, ºF (ºC) ASTM D-92 437(225) 437(225) 450(232) 450(232) 437(225) 437(225)
Fire Point, COC, ºF (ºC) ASTM D-92 >450(232) >450(232) >450(232) >450(232) >450(232) >450(232)
Pour Point, °C max ASTM D-5950 -42 -39 -36 -33 -39 -30
Zinc % wt ASTM D-4951 0.11 0.11 0.11 0.11 0.11 0.11
Phosphorus % wt ASTM D-4951 0.09 0.09 0.09 0.09 0.09 0.09
June 2002
slowlane
US
Thanks, Patman, "Perhaps someone else that I sent that file to could send it to you this week". Anybody have the data from Patman? slowlane Wow, that was quick-vvk [ June 02, 2003, 02:52 PM: Message edited by: slowlane ]
