Driving details:
Nothing exciting in this interval. I'd estimate 70% city driving and 30% freeway.
Easy on the throttle for the first 10 minutes -
Personal Comments:
Copper is back up, but there were no motorsports events or spirited drives. Any comments are welcome!
Current UOA:
Code:
OIL FILTER: Subaru OEM Toyo Roki - 15208AA100
AIR FILTER: Subaru OEM - 16546AA020
EQUIP.MAKE/MODEL: Subaru 2.0L Turbo OIL TYPE & GRADE: Castrol Syntec GREEN 0W/30 (Gas)
FUEL TYPE: Gasoline (Unleaded) OIL USE INTERVAL: 5000 miles
You ran this 0W/30-grade oil 5,000 miles and we found copper reading at 11 ppm, which might be a sign
of some excess wear though we don't think it's a new problem. It's not too high, yet, but it is something to monitor in
future samples. The rest of the wear metals look good showing normal wear. The oil's TBN was 4.8, indicating lots of
active additive left in this brand and type of oil. Air filtration was adequate and oil filtration (see insolubles) was very
good. No contaminants were present. Check back in 4K to 5K miles for another look at copper.
ELEMENTS IN PARTS PER MILLION (PPM)
OIL TYPE GC Green GC Green GC Green M1 10w-30
MAKE UP OIL (qts) 1.0 0.75 1.5 0.5
MI/HR ON OIL 5000 4000 4,100 4,000 Unit / Universal Averages
MI/HR ON UNIT 35,600 27,000 23,100 15,000 Location
SAMPLE DATE 03/01/08 06/08/07 03/02/07 04/08/06 Averages
ALUMINIUM 2 2 3 2 2 3
CHROMIUM 0 0 0 1 0 1
IRON 6 5 6 4 5 8
COPPER 11 9 12 7 10 5
LEAD 1 1 1 2 1 5
TIN 0 0 0 0 0 1
MOLYBDENUM 2 1 2 67 18 71
NICKEL 2 2 2 0 2 0
MANGANESE 1 1 1 0 1 1
SILVER 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0
POTASSIUM 1 0 0 0 0 1
BORON 1 0 2 35 9 66
SILICON 10 12 11 9 11 9
SODIUM 2 0 4 4 3 7
CALCIUM 3356 2902 2923 2171 2838 2395
MAGNESIUM 155 154 134 11 114 109
PHOSPHORUS 858 823 785 601 767 722
ZINC 960 1023 928 713 906 861
BARIUM 0 0 0 0 0 0
Values Should Be
cSt Viscosity @ 100ºC 64.2 64.8 64.7 61.4 58-65
SUS Viscosity @ 210ºF 11.38 11.55 11.52 10.60 9.6-11.9
Flashpoint in ºF 410 390 390 370 >385
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0
Water % 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.2 0.4 0.3
TBN 4.8 5.9 6.3 4.7
TAN
ISO Code
Previous UOA threads:
06/08/07 Castrol Syntec 0w-30 - 4000 miles
03/02/07 Castrol Syntec 0w-30 - 4100 miles
04/08/06 Mobil1 10w-30 - 4000 miles
Personal Comments:
Current UOA:
Code:
IRON 6 5 6 4 5 8
LEAD 1 1 1 2 1 5
TIN 0 0 0 0 0 1
NICKEL 2 2 2 0 2 0
SILVER 0 0 0 0 0 0
BORON 1 0 2 35 9 66
SODIUM 2 0 4 4 3 7
BARIUM 0 0 0 0 0 0
Values Should Be
Fuel %
TBN 4.8 5.9 6.3 4.7
TAN
ISO Code
