Driving details:
I drive the car moderately. I ALWAYS let her warm-up. ~3k RPM shifts when the she's cold and ~4k RPM shifts when she's warm.
Car averages two 7-mile city trips on weekdays and random highway trips through the month.
I tracked the car twice with five 20 minute sessions. (2 x 5 x 20 = 200 minutes)
I also went for a few spirited drives...
This oil went through the tough (sarcasm) Bay Area winter. Temeperatures were mostly in the 40s ºF to 70s ºF.
Personal Comments:
As Blackstone mentioned, the probable cause for the high copper is from the track. The copper coupled with 1.5 qts of make-up oil tells me to use a thicker oil.
The previous sample of Mobil 1 10w-30 looked fantastic and I believe that GC would be on par if not for the much harder driving.
I still have GC in the car, but I'm looking into other oils now. (Delvac 1 comes to mind.)
Previous UOA post(s):
04/08/06 Mobil1 10w-30 - 4000 miles - 2005 Subaru WRX 2.0L Turbo
Current UOA:
This format looks fine Internet Explorer. For other web browsers, see the post below.
Code:
OIL FILTER: Subaru OEM Tokyo Roki - 15208AA100
AIR FILTER: Subaru OEM - 16546 AA020
EQUIPMENT MAKE: Subaru OIL USE INTERVAL: 4,100 Miles
EQUIPMENT MODEL: 2.0L Turbo OIL TYPE & GRADE: Castrol Syntec GREEN 0W/30 (Gas)
FUEL TYPE: Gasoline (Unleaded) MAKE-UP OIL ADDED: 1.5 qts
Copper increased in this sample. Generally this wear metal comes from a brass/bronze
part, such as a bushing but in your case it may be from your turbo. We suggest this because of the
track days you mentioned. We have a feeling that you could probably hear your turbo whining all the
way around the track. I like the way mine sounds and I'm sure you do too. Check back in another 4K
miles to monitor. We think with no track days on the oil your copper should improve. No harmful
contaminants were found. The TBN read 6.3, which shows lots of active additive left.
ELEMENTS IN PARTS PER MILLION (PPM)
MI/HR ON OIL 4,100 4,000 Unit / Universal Averages
MI/HR ON UNIT 23,100 15,000 Location
SAMPLE DATE 03/02/07 04/08/06 Averages
ALUMINIUM 3 2 3 3
CHROMIUM 0 1 1 1
IRON 6 4 5 8
COPPER 12 7 10 5
LEAD 1 2 2 5
TIN 0 0 0 1
MOLYBDENUM 2 67 35 77
NICKEL 2 0 1 0
MANGANESE 1 0 1 1
SILVER 0 0 0 0
TITANIUM 0 0 0 0
POTASSIUM 0 0 0 1
BORON 2 35 19 75
SILICON 11 9 10 8
SODIUM 4 4 4 6
CALCIUM 2923 2171 2547 2403
MAGNESIUM 134 11 73 107
PHOSPHORUS 785 601 693 720
ZINC 928 713 821 856
BARIUM 0 0 0 0
cST SUS VISCOSITY cST SUS FLASHPOINT FUEL% ANTIFREEZE% WATER% INSOLUBLES%
VISCOSITY VISCOSITY INDEX VISCOSITY VISCOSITY IN ºF
@ 40 ºC @ 100 ºF @ 100 ºC @ 210 ºF
VALUES 58-65 >365
SHOULD BE
TESTED 64.7 390
VALUES WERE
Personal Comments:
Current UOA:
Code:
ALUMINIUM 3 2 3 3
CHROMIUM 0 1 1 1
IRON 6 4 5 8
COPPER 12 7 10 5
LEAD 1 2 2 5
TIN 0 0 0 1
NICKEL 2 0 1 0
MANGANESE 1 0 1 1
SILVER 0 0 0 0
TITANIUM 0 0 0 0
POTASSIUM 0 0 0 1
BORON 2 35 19 75
SILICON 11 9 10 8
SODIUM 4 4 4 6
BARIUM 0 0 0 0
VALUES 58-65 >365
SHOULD BE
TESTED 64.7 390
VALUES WERE
