I've been testing various oil for 10K miles. Last sample was Castrol GTX 10W30. As you can see, in this case I don't think the Syntec is worth the price. I'm now testing Penzoil Platinum 5W30 to compare.
1999 Honda Accord 4cyl 2.3L EX Auto
Oil: Castrol Syntec 5W30
Filter: Purolator PureOne PL14459 (10K miles on filter)
Blackstone was the lab used.
This sample had about 5 months of time on the oil, 10,203 miles. I had to add 1/2 quart of makeup oil over the 10,203 miles. Vehicle has 135,656 miles on the clock. The synthetic seemed to burn off a tad faster than the dino oil...that may be due to the lower weight of the 5W30 over the 10W30, but I wouldn't think so.
COMMENTS:
Lead improved nicely here and all other wear continued to read normally. Hopefully lead continues to improve in the next sample. You can see that there isn't much difference between this oil and the last two that you've sampled. The viscosity of the oil was slightly lower but that was expected as this is a 5W/30 vs a 10W/30. This oil doesn't contain as much sodium as the last, and the 43 ppm that we found here is probably mostly carryover. The TBN was a bit stronger and read 2.9 so you still had some active additive left. Try ~11,000 miles next oil.
ELEMENTS IN PARTS PER MILLION
Aluminum: 3
Chromium: 1
Iron: 9
Copper: 5
Lead: 11
Tin: 4
Molybdenum: 85
Nickel: 1
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 1
Boron: 19
Silicon: 14
Sodium: 43
Calcium: 2912
Magnesium: 13
Phosphorus: 718
Zinc: 861
Barium: 0
PROPERTIES:
SUS Viscosity @210*F: 61.1
cSt Viscosity @ 100*C: 10.54
Fuel %: Antifreeze %: 0.0
Water %: 0.0
Insolubles %: 0.4
TBN: 2.9
COMMENTS:
Aluminum: 3
Chromium: 1
Iron: 9
Copper: 5
Lead: 11
Tin: 4
Molybdenum: 85
Nickel: 1
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 1
Boron: 19
Silicon: 14
Sodium: 43
Calcium: 2912
Magnesium: 13
Phosphorus: 718
Zinc: 861
Barium: 0
PROPERTIES:
Water %: 0.0
Insolubles %: 0.4
TBN: 2.9
