Patman
Staff member
If you want to get your oil sampled, here is the best deal going right here:
http://www.bobistheoilguy.com/terry.html
No, I don't think Honda's switch to 5w-20 was "just" to meet CAFE, but to be able to put a higher gas mileage number on the sticker, anticipate tougher efficiency requirements, and market their cars as safer for the environment, etc. My point is that the decision has precious little to do with engine longevity.quote:
Originally posted by csandste:
Question-- Honda's use of 5W20 was done just to get them past increased CAFE standards, right?
Doesn't Honda's excellent efficiency mean that their product mix for mileage is one of the best and far over acceptable CAFE standards.
I could certainly see that reasoning behind Ford's decision to go with 5W20, but Honda?
BTW-- Personally I use 10W30 and agree with the addage about too much VI being a bad thing.
What exactly are they "on to"? Have they put thinner and thicker viscosity oils in identical engines and run them to 200,000 miles and then torn them down? You could probably run sewing machine oil in your engine and reap fantastic power and efficiency gains, until it wore out.quote:
Originally posted by Patman:
Mine does, so if GM doesn't recommend such a thick oil for a high performance engine like the LT1, they must be on to something. (not that the manufacturers are always right, mind you)quote:
Originally posted by kev99sl:
My owner's manual doesn't say anything like, "20w-50 and all other viscosities not recommended,"
I use Mobil 1 0W30 (have used the Amsoil and Mobil 5W30) in my Pontiac Grand Prix with 3.1 v6 and I do not even need to add any until around 3000 miles (I do 7000 mile changes), and then that is only about 1/4 of a quart.quote:
Originally posted by Bror Jace:
Yes, some testing suggests that the thinner oils will get the job done ... but I suspect that this is BARELY the case. Those of us that want our engines to run really well for 200,000+ miles should use something better/thicker.[/QB]
For every story of someone running 0w-30 for 500,000 miles with nary a problem, there's a story of some old-timer running straight 40 weight for 500,000 miles with nary a problem. The oil -- brand, weight, type -- needs to be matched to the engine and the driving. My car drinks Mobil 1 5w-30 like it's water, and I started using it with 9,000 miles on the odometer, in Chicago (extremes of both hot and cold).quote:
Originally posted by icruse:
Yes, some testing suggests that the thinner oils will get the job done ... but I suspect that this is BARELY the case. Those of us that want our engines to run really well for 200,000+ miles should use something better/thicker.I use Mobil 1 0W30 (have used the Amsoil and Mobil 5W30) in my Pontiac Grand Prix with 3.1 v6 and I do not even need to add any until around 3000 miles (I do 7000 mile changes), and then that is only about 1/4 of a quart.
I have 223,000 miles, car runs beautiful and gets around 32 mpg.
Here in Minnesota it does get cold, but sometimes it can heat up in the summer, so I go through extremes in temperature.
And if I visit back home (northern Virginia)it is really hot and humid down there.
Good Day,
Steven
[/QB]
I have a '99 Saturn SL. I ran "Saturn" oil and filters for the first three changes, then switched to Mobil 1 5w-30 with Mobil 1 filter at 9k. Changed oil and filter every 3000 miles or less. At 50,000 miles, started using half a quart between changes. This steadily climbed to a quart between changes until 97000, when I replaced the valve stem seals thinking they were the culprit. (After all, they had to be. I was running the best synthetic oil made, and changing ever 3k, so the engine wear had to be about nil, right? :-|) That didn't do the trick, and I switched to Mobil 1 10w-30: no noticeable positive effect on consumption -- climbed to 2 quarts between changes. Switched to Delvac 1 5w-40, and consumption dropped back to just under a quart between changes. This was more than acceptable, but concern over the high ash content led me to Amsoil 10w-40, which I've been using since 115,000 miles. Consumption was at 1.5 quarts between changes (still every 3k), but climbed again to over 2 quarts. I'm just finishing up an Auto-RX application with Castrol GTX 10w-40. Consumption is the same, and I'll probably go back to the Delvac 1 when I'm through with this application, ash be ****ed. So that's my sad history!quote:
The oil--brand, weight. type -- needs to be matched to the engine and the driving.
I agree wholeheartedly. By the way, what car and engine do you have? And is Mobil 1 the only oil your car is thristy for?
Steven
